Help Please Iq 1.0 Very Weak On Start
Dear All
I own an IQ 1.0 litre 2010, which i purchased recently. Its in top condition, i am very satisfied with it. Since day 1 i was feeling that it was a bit slow at start up. I always had in my mind a smart car that i used to own before and always thought that the difference was because the smart is turbo. A few days ago i drove another IQ the same as mine and i noticed that it was much stronger than mine at start. To clarify what i mean, my IQ accelerates very slowly at start. Some times i press the petrol all way and its as if someone holds it back. Someone suggested that its the catalyst but i had it checked and its ok. Any ideas?
Sounds like the old IQ EGR valve problem which is a known fault on the earlier IQs but some dealerships need more persuasion than others to fix it.
Replacement is the only proper cure as a better valve was fitted to later IQs.
If you do a search of this forum you should find plenty of references to it and those who have had it done may advise you on the best course of action.
John
dear johnan thanks a lot for reply. i will advise the mechanic :)
pou sai re marie :) ate an evreis kanena na allazei erg poda stin Kypro laleis mou
Hi there
Bobkneale on here wrote a very good letter to Toyota about the EGR valve with very positive results. Do a search its in your best interest.
David
Many thanks david, i found the topic and i have send a message to Bob
Rgrds
