Hi, I have an Avensis and find I can't hear the clicking noise when the Indicators are on. I constantly forget to switch them off. Can you increase the sound level on the indicators.
Unfortunately there is no built in option to increase the indicator noise, a few customers I have seen have had a sounder normally used for when a trailer is being towed fitted by a local towbar specialist this give a loud beep when the indicators are used.
  • 1 year later...
Hi
I have a 2010 Avensis TR with same 'quiet' indicator problem. There is a 'motorcyle' sounder accessory that you can source from e.bay that is wired into LH & RH indicators, but will this affect the vehicle electrics I.E as these vehicles use multiplex / can bus style wiring etc?
