How come my hand breaks lights does not turn off even if i already released the brakes?
Th :help: anks
It could just be a sticky switch, have you checked the brake fluid level.
Yup, I did check everything. Is it possible the switch is damage? do you know any compatible replacement for this? thanks
It's normally all the crap that gets down in the centre console, take it out and give it a clean first, and then you can test it.
It could also be the low fluid level switch on the brake master cylinder, they play up sometimes.
I will try this weekend. Will let you know if ever I blown up somethin else! Thanks
According to my manual the handbrake light is a dual light that also means low fluid and or air in system.
well jimma, i have to check my pads if its worn out. Thanks
Well, its the switch that's giving my eye. cleaned it then made a few test and its done :hokus-pokus: :thumbsup: .
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
