Rattling Noise Behind Glove Box
27901591
I have a rattling noise around the glove box, you can only ever hear it when the car is idle and revs are less than 1000rpm, touch the accelerator to increase the rpm just above 1000 and the noise stops and all you can hear is the engine. It gets worse when you have the car at biting point on a hill which the noise increases to a small knocking rather than rattling. Anyone know what the problem is?? Thank you
Is the pollen filter and housing properly located?
After an hour of careful listening and looking, I realised when I fitted the HIDs I forgot to put back one of the screws/clips and the plastic cover was vibrating on the metal, funny how something so small was causing such a annoying noise.
I think I've got something similar happening to mine. Garage changed the diesel filter and since then, there is a rattling noise when revs are between 1500-2000. I thought it was because I used a third party filter but after reading this, I'll have a look. Hopefully its just a clip.
