Wiring Plug
HONDAS
Hi guys does the plug in connector that goes I to the fuel tank of 2003 rav4 only used to read fuel level or what else does it do, I have found my brown and white wire connection to be abit wonkie. Cheers
As often is the case, your profile doesn't say if we are dealing with petrol or diesel. However, you may also find a yellow and red wire that is described as a sub unit (maybe for the low fuel light) with yellow and black going back to the dash.
If you have a petrol, its not a good idea to mess with the tank unit/wires with the ignition on or you might get an aerial view of next doors roof.
Sorry anchorman , it's a diesel, it has 4 wires going into it
What exactly are you asking buddy?
Where or what these wires actually do , are they only to operate the fuel gauge on the dash, cheers
The fuel light and gauge. Nothing more.
Anchorman could u please tell me what fault code p1250 turbo system malfunction could relate to
My computer is being a proper PITA. Can somebody find him the P1250 pdf?
Ta.
