Short Shifter
Echosqwat
how much and where from?
Erm...whats a short shifter?
Matt
its a different gear shift that has different angles and movement set to it.
namely alot smaller so the travel from gear to gear when changing is a lot shorter and therefore quicker
only thing is the gears can be a bit harder to select as you have less leverage to lock it into place.
:thumbsup:
