Drop Links
Phil_1985
My 2007 67,000 miled Auris 2.2 T180 is due it's MOT in 3 weeks - I've noticed that the bushes on my anti roll bar stabiliser links have split on both sides. This is visible on full lock steering left/right only.
Do I, hope for the best when Toyota test it in 2 weeks time that it'll be covered under my MOT test cover which is part of my Toyota extended warranty or get them fixed before?
This is all assuming that it's an actual fail. No noises or clunks from the suspension.
Phil
no noises or clunks from my suspension,and my car failed its mot for worn drop link bushes( mot at toyota dealer) new drop links fitted
did you have toyotas extended warranty/mot test cover as well?
decided to not bother with the risk - got them done at kwik fit this morning, took half an hour. £92.00.
