Breaking 2.0 D4D Y Reg Estate
gaml d4d
Hello
My trusty Avensis has finally let me down, sounds like it ate a piston last week . Oil pressure looks the likely suspect, had problems the month before with the sump pick up getting clogged. Car had done 238,000 miles so not too bad.
It's got too many good bits to just scrap and it's sitting in my garage at the moment so any thing you are interested in let me know. Bits replaced in last few months include, starter motor and fuel pump,timing belt, rear shocks, the body work is very straight and everything still worked (as you would expect).
I've been offered £200 for scrap, but would rather someone on here got use of the good bits first.
The car is in Rochester in Kent and you can come and have a look or I travel every week to Berkshire so can drop bits off anywhere in between.
Graham
What colour is it? I'm on the lookout for some parts and may also be coming to Kent in the next month or so,
Hello Richard,
I should have said. It's silver.
Graham
