2012 Avensis 2.0 Diesel
Pedal Head
Not had the car long but I've noticed that when accelerating reasonably hard at motorway speeds there's noise that can best be described as a squeeking warble at 3-4 hertz from the engine compartment only while the accelerator is down. I'll be taking it up with a dealer but in the meantime has anyone else suffered this?
There are lots of owners with a vibration coming from the airbox intake pipe. It has a foam rubber gromit on it that wears away causing a 'broarr' noise occasionally. Self taping screws or silicone sealant or similar fix it. Dunno if that fits with your symptoms?
That sounds like a good description, would that be the rather flimsy foam ring where the intake pipe enters the filter box?
That's the culprit. Reseated it last night, not cured but a fair bit quieter.
Cheers for the tip.
