I have a engine noise can anyone help with? idle is ok only when the revs get to 2000rpm does the noise appear. I suspected the turbo at first but the noise does not come from the turbo area. there is no smoke from the exhaust and the bus drives ok. i have added a youtube clip of the noise.
thanks
Stuart
Ok the noise is comming from the turbo, can anyone tell me if the actuator should be very easy to move mine feels like it is heaverly spring loaded!
I can't see any cracks in the manifold.
thanks
