Arghhhh...... Again!
Pogle
Last week I removed and cleaned the EGR valve. !Removed! warning light has come on again with the same code (0400 from memory?). Does it look as though I haven't done the job properly or is there something else in the EGR system that could be unhappy?
Pogle
Andy.....is there any chance that you reassemled it minus one of its gaskets, the one at the cylinder head end.....? I forgot it was there, and it fell aff at removal, and I found it after a short test drive to Halfrauds for another reason......with bloody light on and in limp mode.
Andy.....is there any chance that you reassemled it minus one of its gaskets, the one at the cylinder head end.....? I forgot it was there, and it fell aff at removal, and I found it after a short test drive to Halfrauds for another reason......with !Removed! light on and in limp mode.
Thats why you should not be pokin around under engines BK :rolleyes: *sighs*
Lisa Lane.
If he's cleaning the EGR "under the engine" he IS in trouble!!?!
Dave
No really Dave......quick skim of the commutator and some new carbon brushes on the solenoid pre-engaged actuator and ma EGR valve was branny new.......
Is there just the one gasket on the EGR....the one where it mates to the engine block/head itself or is there another I have missed?
One each end mucker......
Other end?.....I seem to be an end short. Is that where the electronic thingy bit bolts onto the top of it with 3x bolts?
There is the main gasket (25628 number 1) and the smaller gasket on the pipe (25628 number 2)
EDIT Ooops, forgot to attach the picture :D:
Andy.....don't hit me for asking......did you clean oot the pipe too when doing the valve, mate.....?
Pipe? No just whipped the valve off and cleaned the uppy downy moving whatsit.
Oops mate.....wee error methinks.......pipe may be sooty, and similar to ma arteries in general.....,
