Carina E Engine Swap 7Afe Engine Starts But Only Runs For 10Secs Then
just swapped out the engine and gearbox , from 1.6 4afe auto to 1.8 7afe manual . changed ecu to 7afe and wiring loom engine starts but will only run for 10 secs then switch off reving it makes no diffrence it still dies, the fault codes i am getting are code 99 what does this mean , have i missed an important bit to swap over . engine sounds fine but dies.
thanks for your help...
Ok im getting there now its to do with codes being swaped from the ecu to the immobiliser anythink abouth 500rpm it will send a code but because iv swaped the ecu the code will be inncorect so some wiring to be done .
code 99 is immobiliser fault.
still cannot get ecu to work
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
