How To Open When Key Fob Battery Dies?
Aerodeck
Hi All.
Both my key fobs are failing on Avenisis 2002.
How can I use just the keys? When I open with the key only, the alarm sounds.
Is there any way of disabling the alarm and just using the key?
Any help appreciated !
After opening the door with the key and the alarm is sounding put the key into the ignition and switch on. The alarm should stop.
Fitter
Have you put new battery's in your key fob. They sell at wilco ! It's easy to do .
Hi.
I have changed the batteries in both and they still only work sporadically. The LED is bright, then dull, then bright again - like there's a dirty connection, but I can't find where.
I tried the keys in the ignition when alarm is sounding ... doesn't work.
Where can you get replacements? Seems hardly worth it on a £500 car unless they are under £20.
If you lock the car with the key the alarm does not set, so just use the key to lock and unlock.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
