Rav4 - Rev'ing Problem
GSXBandit
I have a 2003 4D4 which will not rev past 3000rpm, has anyone had a similar problem and what did you do to solve it?
Early D4d Ravs can suffer from a blocking of the front pipe exhaust, if possible remove the front pipe and see if this helps also the fuel filters can collapse internally causing fuel starvation. Do you have any warning lights?
check with EGR and change fuel filter
regards
My Rav4icon1.png did the same thing and I am posting all over the forums what fixed mine. It was a bad fuse! It was a 10amp fuse that had gone bad on my 2001 rav4 base model 2.0 2x4. I hope this helps!
