Auris Brake Discs
sooty11
Anyone know the dimensions of the back brakes on a 2007 1.6 auris? I've had a look online and there seems to be several sizes, anyone know? Thanks.
Hi there, hope this info helps.
Regards
Allan
Brake Disc Thickness [mm] 22,0 Brake Disc Type Vented Centering Diameter [mm] 62 Diameter [mm] 275 Height [mm] 46,3 Hole Arrangement / Number 05/07 Hub Diameter [mm] 62 Inner Diameter [mm] 144 Minimum Thickness [mm] 19 No. of holes 1 2 Number of Holes 5 Pitch Circle à [mm] 100 Quality ORIGINAL HERTH+BUSS Supplementary Article/Supplementary Info 2 without wheel hub, without wheel studs Weight [kg] 5,88 Engine Code 1ZR-FE Fitting Position Front Fitted Quantity 2 Other Information VIN 1st Digit J
