97 Rav 4 Quit Running
patfrank
I was headed home Friday when my Rav 4 died, it will spin the motor, has spark and gas to the filter but will not start. I pulled the valve cover and the timing belt seems ok, the cams are turning, but it does not even try to start. Computer? EFI relay? any suggestions? Thanks, Pat
Immobiliser kicked in?
Earth strap?
Petrol blockage?
Fuel filter needing checked?
Checked the fuses?
Spark plugs needing changed?
Hope you find the problem, and welcome to the forum.
