Avensis 2004 T25 Headlight Bulb Covers
Azzawacker
Hi can anyone help I've replaced the bulbs in my car today and came to putting the driverside rear bulb cover back on ...I know what your all thinking yes they are a bugger to get back on but the inside locator tab broke and now the cover won't stop on ! Can you buy just the covers or is it just a case of buying a new headlight ? Or has anyone had this problem and found a way to resolve this problem ? Any help would be good
Cheers mate the bulb holder is fine it's the black cover that stops the rain and water getting in that's broken
The headlights were modified and so was the cover on the back, you can buy them at your dealer
Kingo :thumbsup:
Cheers jingo il pop down at the weekend and see cheers mate
Yes you can get them from the main toyota dealer, don't forget to order off side or near side. Also you may need some new press in clips for the plastic trims . I did . I think it cost me about £20 for 5 new clips + headlight back cover. Be careful next time !
Hello dog 7 are these the clips that hold the plastic surround covers to the body ?
Yes they are & don't forget the screw down cap for the Battery cover . Keeps every thing from rattling around. I had a new timing belt fitted at 120K you would think that toyota main dealer would fit new ones were needed but they don't .
