Side Wing Indicator Avensis 2002
mokhali
Can someone plz tell me how to remove the side wingindicator and change the bulb on my 2002 avensis
Get a flat head screwdriver push the orange reflector rearwards from the front, then pull the unit away. The bulb holder can then be twisted off to unplugged (bayonet style). The bulbs are the same as used in the side front lamps/rear number plate illumination.
Jobs should take about a minute. Try not to touch the new bulb.
