Faulty Earth Strap
BJB
Some information which may be of interest / use to others in the future.
Rav4 has just been in to dealer to check a Power Steering alarm. Symptoms were 'red P/R' fault light and although the power steering worked. the steering very heavy but drivable. I have in the past, had a complete failure of the power steering when I lost a drive belt. Then I could hardly turn the wheel.
Fault came on when starting in the morning. Restarting after a run, no alarm.
Dealer has diagnosed a corroded engine earth strap and a replacement is on order (Toyota approved used warranty).
I am thinking that the high resistance of the corroded strap meant there was a higher than normal voltage drop when starting a cold engine which brought up the alarm. Starting a warm engine would require less current therefore the voltage drop would not have been as much so no alarm.
Any thoughts re the diagnosis?
Bryan
I've had problems with the earth strap corroding. Got 2 more fitted. I think it may be more common than folk think - depending on how old the car is.
