Avensis 2007 Car Stereo With Sat Nav. Does It Have A Code?
Madmillie
Need your help guys.
Just had the car 57 plate Avensis T4 2.0 D4D back from local indie garage following air con condenser replacement. Battery was disconnected to enable strip down. Drove home and turned on the stereo and nothing, no volume at all..... It's the touch screen sat nav stereo with the flip up front for the sat nav DVD and the CD.
Garage said it must have a code and suggested that it should be with the handbook. It's not!!! Any ideas whether I need a code, and if so where I can get it from?...
Steve
I had a 58 plate and there was no code in that I had the Battery disconnected a few times, in fact I don't think Toyota have used coded radios in any of the satnav units.
It's possible that when they put things back they have missed a connector?.
As far as I'm aware none of the later Toyota radios have a code - see also http://www.toyotaownersclub.com/forums/topic/150185-information-on-my-2006-d-4d-22-t180-please-dpf-radio-code/ (especially the 6th post)
