Rav 4.3 Brake Disks & Pads
stevepen
Looking around to change the front pads and disks on our 4.3 2,0 vvti Rav.
Found some on eBay, Mintex MD 1850 pads and disks in one box for £96. Has anyone tried these or can recommend any others?
Have used Mintex on other cars with no problems but APEC currently on RAV and certainly superior to original Toyota which deposited badly and corroded as a consequence. Braking noticeably improved too.
Concur with Davrav on Apec products, but Mintex well trusted name too.
I have used the "Mintex Brake Box" kits before.. You get everything you need for the job at ace prices and the quality is Ace....
Thanks for the quick responses. Does the 2.0 vvti use the same disks as the 2.2 d4d?
There are two different diameters of disc that fit the 2.2 diesels, so beware......
Eurocarparts lists 296mm diameter front discs for both petrol and diesel 2007 RAV but it would still be worth measuring what's on yours to be sure Steve.
Try Milner Off Road near Matlock, Derbyshire www.milneroffroad.com
Dealt with them for years for Toyota, Misi's Diahatsu etc. can't fault them.
Just under £100:00 for the two wheel sets, (new discs and pads.)
I am merely a very satisfied customer, having no other connection with the company.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
