Avensis T27
Valvematic
behind the front wheels on the inner wings are covers which are fitted with press stud type clips. Mine seem very loose and I think they are a cause of a rattle I hear (the car is so quiet you hear everything, I think I should VTEC more)
Are everyone else's firmly fixed with no movement?
Will check when next at the stealer.
thankyou.
They are just a push fit. plastic into metal, so not a tight fit, you will feel a little movement. The car is quiet but not so quiet you would hear those clips rattling
Kingo :thumbsup:
They will be loose, they are only push fit clips, there is a lot of flexibility in those liners and if the were solid to the bodywork you would get a lot of drumming noises
Kingo :thumbsup:
