1996 Ln106 Hilux Vibration & Right Rear Wheel Oil Leak
unbreakable
Hey people, im a new truck owner and need some advise!
I am just in the process of buying a new rear wheel bearing and want to just make sure (cheaply) it is the problem. At a speed of around 80km and again 100km a vibration starts up but dissapears at about 110km. The truck is leaking diff oil out of the rear right wheel quite badly. When i buy a rear wheel bearing online do i also need to buy a seal or does that come with it.
cheers
cheers
Vibration can be caused by loads of things, does the rear wheel bearing sound rough when you spin it after jacking it up ?
Obviously the oil seal needs doing so inspect the bearing then.
Don`t forget the join the Hilux forum below... HPOC ;)
