Rav 4 Nrg 3 Door..central Locking
ravvi
hi there,i have a 2002 3 door rav..when i lock the vehicle with the key fob, all doors lock except for the rear boot door ,i can then open the door although the alarm is activated..can anyone help.. thanks
Hi, I have a problem with my central locking, I simply can't lock or unlock any of the doors, the LED lamp is not blinking at all whereas the immobiliser LED is. Is there a fuse anywhere that might need replacing? SORRY I can't help with the other problem posted earlier.
What happens when you press it twice to activate the deadlocks?
Does the led on the keyfob light when you try to lock it? Apologies if it seems like a numpty question. Is it a newish Battery in the fob? The security led flashes until you put the key in the ignition when unlocked but the one in the centre console doesn't.
Its a fairly new Battery - less than 2 months ago. Would reconnecting the Battery after recharging incorrectly have any adverse effects? - ie do I connect Plus first or Minus.
Its a fairly new battery - less than 2 months ago. Would reconnecting the battery after recharging incorrectly have any adverse effects? - ie do I connect Plus first or Minus.
You've lost me. Can you charge the Battery in the fob? After recharging the main Battery (the standard petrol one is too small) incorrectly - what do you mean by that? You connect the plus first on most if not all cars.
