ok so I done a search as a friend wants to upgrade hi corolla g6 from a 4efe to a 4age 20v blacktop engine looking at buying a complete corolla rsi with blacktop already in
now the questions need are
1. if i'm correct engine and box will drop straight in and bolt up in place
2. normally you would use Levin loom and ecu and wire in to original wiring of car however I have a corolla already albeit the rsi and slightly different shape could I (providing there is no immboliser on car just change ecu and it work??
or could I use the complete loom out of the rsi ?? both 4 door one saloon one hatch
or would I have to wire it into g6 loom
if I have to wire it into loom does anyone have any diagrams that might help with this thanx alain
  • 3 years later...
Hi Alain,
i know this is an old posting - just wondering whether you have done this swop and id it work out ok.  i am thinking of doing something similar with an E11 saloon and also just checking if you still have this donor car available? Thanks Rajin
