I have an 1992 MR2 GTS (jap import) I need front disks for it and the cheapest price I am getting is £180. Does anyone know were I can get them cheaper. Also are the disks the same same as the 2.0litre MR2?
The disks are the same across all models .. check the revision of your car as there are two sizes .. rev1's have smaller, rev2+'s have the bigger ones ..
I got Red.Dot disks (grooved and drilled) for about £180 per axle ..
You can get stock ones for £40 a disk ..
bibbs can't the l8r model disc be retrofitted?
i was thinking of getting some from the l8r tubby as they are much better than stock rev1 n/a discs.
Proper brake upgrade will come at a l8r date tho.
-Z
If you hold on a day or so, you will find one of the countries top Brake manufacturer/supplier will be offering discount to Gold Members ;) :P
And then there should also be another for the more budget concious.
BTW, I replaced the discs and pads on both fronts of my Rev3 MR2 last year for less than £90.00 from one of the soon to be discount suppliers mentioned above ;) :thumbsup:
Does anyone have any contacts or information on were i can get a pair cheap? I can't get them cheaper than 69 per disc!
www.IMOC.co.uk .. then click affiliates ..
