98 Rav4 Abs Fault
cav85
wonder if anyone can help.
i got a 98 rav4 2 litre petrol and every so often the abs will kick in even when u hardly touch the brake but no abs light comes on the dash ( even had the codes read just to make sure) thought it would have been a spilt in the abs ring but thats not the case.
if anyone has any ideas i would be greatful
This might be a daft question but does your car have the "self-priming" brake system? i.e. where if you hit the brakes hard in an emergency, the system ups the brake pressure by a substantial amount. If so, might there be a fault with that?
Had a customer complain about a similar thing recently............turned out to be worn out tyres losing grip
Kingo :thumbsup:
