Replacing Right Turn Indicator Bulb (Jdm 2003-2008 Avensis Tourer)?
Ironbeard
Looks like just Google isn't my friend in this regard. Could anyone give me some guidance on how I possibly go about replacing a burnt out turn Indicator bulb on the Rear Right hand light cluster?
Taking the lining off and taking a series of photos suggest that it looks like I will have to remove the entire array just to get at it?
post-132689-98976_thumb.jpgpost-132689-0-53011300-1377058354_thumb.
Alright, have managed to get it out. Apparently all 3 bulbs in the cluster rested in one plastic holder which is held in place by 4 clips (2 pairs). Had to feel my way around, but Unclipped the upper pair then unclipped the lower pair and was able to take the cluster out and replace the burnt bulb (The middle one in a cluster of 3).
post-132689-0-53467200-1377071317_thumb.
It is probably one of those things that would be explained in the owner's manual, but if you have a JDM Avensis then it may be a struggle to decipher (unless you can read Japanese of course) as these cars usually come with the Owner's manual in Japanese.
