Prius 2010 Owner Aks For Help
jiaqi
Hey, guys. I have a dvd radio for my black Prius 2010 ,but I don't know how to install it because I am not familiar with something like this, so I come to here ask for your help. Maybe you can help me.
The people on this forum can be very helpful but you need to give more information if you want a helpful reply.
It would be wise to explain what model of radio you want to install and also which model Prius.
The best place to look is over on Prius Chat.
http://priuschat.com/f/gen-iii-2010-prius-audio-and-electronics.98/
Start with this thread.
http://priuschat.com/threads/2010-toyota-prius-model-ii-head-unit-upgrade.73884/
The one thing you need to be aware of is that the 2010 gen3 head unit comes in left hand drive and right hand drive versions. Not because of the knobs but because the dash isn't flat.
Check this thread.
http://priuschat.com/threads/in-dash-navigation-for-right-hand-drive-prius.90622/
If you are going for an OEM look you need to get the correct unit otherwise it doesn't fit.
If you are going for a generic double DIN unit, you need to get the correct surround and possibly blanking panels (or leave a massive gap). You will also need a suitable wiring harness. If your 2010 has the JBL upgrade, you will also need to check that your unit will support that.
