4age Tvis
T BALL
ive got a 4age im checking over before i put it in a Shell. when i took off the inlet manifold the tvis system was seized open. i never had the motor running. i want to know what are the affects/problems of using the engine with all the tvis stripped off and just leave it in like a spacer. im guessing less torque. would it help to remove all the tvis blankers if the head was going to be worked on?
