My Hilux 2.5 4X4 Common Rail Starts And Stops
Hello everibody: Can anyone heard about a hilux 2,5 common rail that stars and stops at 2 sec? That my trouble. what can be the problem ?
cancun
Fuel ? have you tried pumping primer on top of the fuel filter ?
Thanks for your reply. Yes, that is a good first solution and I did it often, but is showing me that the problem can be the fuel when starts because then the truck goes normally with all power.
Is the problem only with the first start of the day ?
Glowplugs have you checked them ? try preheating a couple on times before trying to start
Thanks, I could solve the trouble getting a new stronger Battery, the old one was a 75 Ah and the new is 90 Ah , today 5 am it started very well with 10 degrees celsius. Isn't amazing? Maybe that flow valve at common rail ,that is an electrovalve, didn't be opening or better could shut a seconds later for decreasing voltage. Thanks very much all people there!
