Front Wheel Bearing Kit
jimtaxi
Any one know about a wheel bearing kit that comes with bearing already fitted into the hub it appears that this would only entail unbolting the hub bearing carrier to renew the bearing. Any info on this would be appreciated Thanks
The bearings are seperate press in items.
I just changed both mine myself. The hubs are expensive. I would not buy a second hand hub unless the bearing has recently been in stalled. You will know because the bearing will be fairly clean with no rust.
It doesn't take that long to change and if you know a friendly garage they can press out the old and press in the new bearings for you. I have my own press.
Kon
