I think the skweaking noise is coming from my alternator, because the alternator looks like it is kinda bent to the leftbut dont want to waste time if that is not the problem....
if its bent to the left then its the belt sqeeking because its under tension due to vibnrations or lateral movement. bend the alternator to where it should be then make sure the belt is tight. also check the tensioner pulley and make sure it is keeping the belt tight.
