Toyota Avensis Good Tow Car?
Steverav1
Guys is the avensis 2.0vvti 55reg a good tow car if so what is the max weight it will pull and what would it pull comfortably as i have never towed a caravan before
Cheers
Steve
Max braked towing weight is 1400kg so depends what caravan you have. I'm sure it would pull most caravans OK but might struggle with bigger ones and would certainly have probs with twin axle vans. Look at your max weight of caravan + contents and if less than 1400kg you should be fine.
Cool ive been looking for one as light as possible so ive seen a few at around 1000 kgs fully laden by the sounds of it the car should play with this no problem wanted a light one due to not towing a van before so i will be learning and will be going steady till i get used to it
What mpg should i expect to get obviusly it will go down
Cheers steve
