Battery Change And Alarm
Phil22O
Hi, I have to change the Battery on my 2006 RAV4 NRG (2000-2006 model). When I disconnect the negative terminal I hear the pip pip pip which I think is the fore runner of the alarm going off. If I reconnect the negative all is well and car starts. Does anyone know if leaving the Battery disconnected for a while (time to change the battery) will the alram sound and if so is there any way to prevent this. I am assuming Toyota gave some though to future Battery changes and has a procedure to do it, I just don't know what it is.
Regards P
Ignore the wee beeps, Phil, and fit Battery.....been there twice times with no ill effects.
Welcome to the forum (aka madhouse) as BK says ignore the beeps they stop eventually. The petrol model really needs a bigger Battery (we've all been there - buy the diesel one - several threads about this) The car will maybe cut out at junctions for the 1st day.
Why for would that be, Paul, cutting out at junctions.....?
I think it's do with the ecu learning stuff (technical term) Mine certainly did. It didn't seem to like idling and I think this has been mentioned before.
Many thanks for the speedy replies, much appreciated. I'll give it a go tomorrow.
Regards Phil...
