Ac (High Tension?) Wires
S1LKY
Hi Guys,
Newbie to the forum here but hope someone out there can help me.
I'm installing a remote engine start onto our Avensis 1.8 petrol on a 53 plate and have come across a problem. So far with the cables i've attached behind the ignition barrel i can get the engine to start remotely, but the device does not sense that the engine is starting and continues to try and restart a further 4 times and then turns off the engine. There is a wire which the description says is for "AC sensing" and should be wrapped around an AC wire 15 to 20 times.
I am guessing this is meaning an Alternating Current rather than Air conditioning sensing to determine whether the engine is running. My problem is Where do i find an AC wire on this avensis???? as it has no coil, distributer etc....
Thanks in advance
