Few Problems With 07 Plate Auris 1.6 Manual
Gzaz84
Hi, im having a few problems. 1 is when i turn the steering wheel to the right just before full it gets a grinding noise, driving and standing.
The 2nd is after around 20 minutes of driving it gets difficult to put in 1st and 2nd, and 5th grinds a little and reverse also. The 3rd is i cant locate the clutch oil resevoir.
Any pictures, directions and advice is welcome. Im not too good with cars but ill try most things once.
If you need more info just ask ill try my best.
Also there is a squeekinf noise coming from the gearstick thats when the gears are hard to change.
Some cars actually share the same reservoir for clutch & brake fluid, but I don't know if yours does. Perhaps a current owner can help with this one please ?
I was thinking that it could be shared with the brakes. Ill try to track the pipework. Any ideas how to solve the squeeks and grinds? Or cause?
