Need Help With Install
bamba
Hi, just finished putting the stereo in (thanks for the write up great help!) and now its time for the rest (2 x 6x9's, amp, etc). As i'm sure many of you will have done this before me could anyone give me a little advice as to:
1) Where the best place (neatest) to run the wires for the 6x9's is?
2) Where the best place to bolt the amp is (i was thinking under the drivers seat)?
3) Where the best and easiest to get to earth point is for the amp?
and finally
4) Where the grommet to run the power lead to the Battery is?
Thanks all :thumbsup:
Ok... wires.... under the plastic sill things by the doors, then under the carpet under the rear seats.
Amp... dunno, 'cos I built a box thingy with sub and amp together...
Earth... drill into the chassis :arrgg-matey:
Grommet... look where the loom disappears into the cabin, directly behind the Battery... push some wire through there and wiggle.
Eventually it drops into the passenger footwell! :D
