Change Bulbs Of My Speedometer
lampie
Hai,
I want to change the lights of my speedometer.
Is this possible and if so, which bulb do I need? How mant watts is a bulb?
And most important, how to get the speedometer out of the dash?
reagrds
Dennis
If Toyota have not changed the bulb spec from the Mk1, your Mk2 should use the same R284, 12v, 1.2w bulb. Other option is the R509 of the same rating but with the holder.
I cannot really say how you access your models instrument panel, but the following may apply.
Lower the steer wheel.
Undo screws securing the instrument panel surround, and remove the surround.
Undo screws from the instruments and pull it forward, then tilt the top towards you so the back is pointing up.
You should the see the bulb holders.
Locate and check the one you need to change. It might be better to remove the bulb first and take it to the shop.
I hope this helps.
Konrad
Thanks for your help!
Any idea how many bolts are fitted in the display of the speedometer?
regards
Dennis
2 bolts are shown. Look around and feel for the holes. On my car the screw holes are in upper part but yours are lower down. There may be tags holding the display in place.
What you need to do is observe how everything is put together.
Unfortunately there is no Haynes manual for the Mk2 Avensis. There may be pdf files on how to dismantle Mk2 dash to change the bulbs.
Konrad
Hi Lampie,Could do with a "how too" on this subject ,there are a few people that would like to do this .
Thanks Micheal for your answer.
Sorry, don't understand what you mean...(dumb dutchman here).
If you mean how too finf out how many bulbs I need, how to replace etc, then I hope that I can get all the help I need.
I forgot to ask 1 question: can i still adjust the new bulbs' sharpness?
reagrds
Dennis
reagrds
Dennis
Don't believe your a dumb Dutchman...no such thing is there :lol: ...no what i mean is, if you attempt the job in question and your confident that it will be a success and you also have a Digital Camera you can take some step by step pictures and download them onto the site thus helping others that may want to do the same thing..hth...oh and have a look on this sight it might help with your decision,as i said i am looking at doing the same thing cus i dislike the original Orange glow it has at present.Would prefer Blue actually. :D
http://www.autobulbsdirect.co.uk/car-and-motorcycle-bulbs/
Just input your Reg Number and it will give you comparable bulbs available.
Hai,
reagrds
Dennis
Hello Dennis,
I have attached a .pdf file that shows all you need to know hopefully.
Regards Pete.
INSTRUMENT PANEL.pdf
Thank you so much for this!
reagrds
Dennis
Glad to help Dennis,
this is what the forum is all about mate ;) I hope you get it fixed now.
Pete. :thumbsup:
reagrds
Dennis
Pete. :thumbsup:
Pete,
This is a perfect example of where the Haynes manual would have helped.
Anyway as you said, this is what the forum is about.
Top bloke.
Konrad
I will upload the results when its done.
Again thankS!
regards
Dennis
reagrds
Dennis
Unfortunately there is no option for avensis verso 2004 (2.0 vvti)
So will go on searching :)
