Obd Port
S2Sosmart
Due to an ongoing project I need to remove he panel below the steering wheel (I didn't need to remove it when I took my dash out).
I've removed the 2 bolts, disconnected the bonnet release catch, unplugged the connector that's in the way but I'm now stuck ! 😁
The OBD port doesn't push, pull out. I've tried pinching the lugs in all 4 corners but still no joy !!
Any suggestions ?????
Si 😩😩
  • 4 months later...
Hello,
The port is secured by 2 clips. Use a small flat screwdriver to compress the clip on one side while pushing out the port. Once the first side is free, the second one will be easier and the port will extract (pedals side).
hi Christophe
I think Simon has done that now after speaking with him as the post was in October last year
David
