Growling Noise At 1600 Revs
thaiad24
Hope someone can help, im hoping its nothing major
ive done 130,000 miles
about 1 month ago i noticed that when i took my foot off the accelerator, the engine made a growling/drone-ing noise. I thought nothing of it
Its happening more often now, maybe 20-30% of the time
it happens even when its out of gear and i rev to 1600-1800 rpm and as soon as i take my foot off it makes the noise, once it drops below 1600 rpm the noise goes away
the noise sounds like its coming from directly in front of the passenger side under the bonnet
hope you can help
cheers
Adam
I think it might be coming from the turbo as tho its blowing
anyone else had this? is it a big problem? the car still works as good as normal
As you've had no replies I'll throw in a suggestion to check the air intake/filter assemby. I'm pretty sure it rattles on some Avensis, not sure if your aprticular model is one of them tho.
Try removing your air fliter. You will find that the air feed into the filter box is not a tight fit. Use a couple of pieces of duct tape to hold the intake rigid. Refit filter. Silence is golden. Seems to happen when the colder weather arrives. Good luck.
