Vibating Tbar Panel
Jimlad
ok... since Toyota swapped over my tbar glass ( they put new glass onto the seals/locking mechanisms etc ), the drivers side one creaks like a bugger. I know exactly where it's doing it from so if I open the window and press on it it stops. It's just where it meets the car on the inside if that makes sense ? If you're sitting in your car and twist your head round... where the plastic meets the plastic of the car pillar.
The thing is it didn't do this before they done the swap. So surely if I take it back and tell them to fix it they will ? I could easily do it myself as it may just be a case of the eccentric rod guides needing adjusted, but the last time I took one apart I frigged the spring clip.
They should sort it for free right ? Especially considering how much money I spend there.
if they didnt do the job rite then ur well within ur rites to get em to sort it out. specially considering they're a main dealer!
-Z
