Help And Advice Needed For My Avensis
Chasedadream
I have a avensis T2 5dr 2.0 D-4d man 55plate that urgently needs a air con pump (looking for a used one)
Will a 2001-2003 model fit this (ones available on eBay )
not sure on your question. I would be suprised if it did but If you fail to find one, and can do away with your aircon it can be bypassed by using a belt from the mk1 avensis without aircon.
try to find someone to repair it,people that work on house air con can advice you,bearings,O rings and pistons are not that complicated to change.
Ok but will a air con pump from a 2002 model fit ?
I would say NO. I would of looked into it at the time. I have just quickly put my reg into eurocarparts and they list different part numbers.
toyo diy list part number 88310‑05100 for t25
for t22 it lists part number 88412‑44050
