Any Alternative To Denso 095000-7610
Susa
Hiya, I'm new, and currently in shock as I have to replace 3 of my 4 injectors in my Avensis. I have been told I need Denso 095000-7610 's looking around this will be around £600.
Is there an alternative on the market I could use? Very unhappy as I love my car and bought this one to avoid breakdowns. Had a bad experience in my VW with my children once and I'm paranoid about breakdowns now :O(
Any advice greatly appreciated - oh, and mine have been condemned - beyond salvage.
Hi.
What was the problem, white smoke, difficult to start the engine or...?
What were diagnostic results for faulty injectors? I mean compensations +/- ? mm.3
Would need to know more about the codes and problem! If its black smoke there are things you could try to do 1st b4 you send hundreds of pounds on injectors! Changed the fuel filter and put BG244 in the tank with some Shell V-Power diesel! Give it a good run... But we need to know more to help🚗💨
Hi, it was being juddery so I took it to my local garage who put it on a diagnostic machine (?) They then sent the injectors off to a man who knows about these things, he has said 3 of the 4 are beyond repair but the other one is OK. He's given me the option of finding my own and fitting then rather than going for OE parts. I just don't know really.
I've had the fuel filter changed 3 times lately. Once in a service in Dec, again in around Feb - followed by a new Battery when it didn't work, then again in September when I asked them to as I was hoping that was the problem. Clearly it wasn't!
A puff of smoke intermittanly when you start the engine, but not smokey to drive.
Very sad as i'm losing faith as time goes on. I don't cope well with cars I think as unreliable, it may have to go when its been mended. Thanks for the support though.x.
