Avensis Auto Headlights On Tspirit
golders
Hello Guys,
Our Avensis has auto level adjusting headlights, so we don't have the dial inside to manually just them up or down.
The headlights are very low and I think this is due to a suspension part being replaced before we got the car. Does anyone know if a normal garage could reset the system or is it a trip to the Toyota dealer only?
Many thanks,
Rob
Hello Rob,
Yes the headlights can be adjusted manually at the back of the headlight assembly there is an adjuster, my car has the manual levelling on the dash but even on the highest setting it was still poor so I adjusted them at the headlight end. As headlights go they are still rubbish but unless you fit better bulbs you will have to put up with it. There has been many discussions on here about the headlights so have a search for more info.
Regards Pete.
