Does anybody know where i can get uprated bushes for an RA40?
Does it share any componenets with earlier or later models so I can use them instead?
Tony
Have a look on the rubbers for a serial number....could well be the same as an AE86. I'll check the numbers against an OEM AE86 set I have and if they're the same you're laughing - TRD rubbers, Superflex/Whiteline PU's or custom rod-ended pieces are available.
There's a good chance since the TE71 shares the AE86 rear-link/bushes set-up, so it's likely that a 6.7" reared RA40 should as well.
