Number Plate Lights.
Roney
Hi can anyone tell me how to change the number plate lights on a 57 reg avensis hatch back.Many thanks.
Hi there mate open the boot up and look at the plastic boot cover on the inside and you should see two plastic squares that pop out using a flat screw driver ! Once popped off you can see inside the boot lid itself plus you should see the bulb holders that hold the bulb . Just twist the bulb holders and they pull out and then the bulbs can be replaced just reverse the process to re assemble hope this helps mate
