Tunit Box Up For Grabs :)
Mistermena
Take a look at a dyno of our kit
Max torque at 2463 RPM, and a whopping 379 ft lb or 513 NM
Max HP at 3637 RPM is 212 BHP
Any decent kit should give more torque, if it does'nt, it is no good, it is entirely possible to gain lots more torque. The kit we use has been adjusted downwards slightly from the above figures because driving the car with 212 BHP is uncomfortable, the power is either on or off, we have adjusted it to just under 200 for a smooth and comfortable drive that will put a huge smile on your face :rolleyes:
Those kits with multiple adjustment USUALLY are a one size fits all kit, they have no specific engine file inside the box, so the box has multiple adjustment, this is so that one of the settings will be near enough for most people. That is not good enough, he kit should be at least suitable for a set manufacturer
Black smoke is typical of kits that just overfuel, if the boost is adjusted too, then you should see very little extra smoke
If anyone wants any more info, PM me
Kingo :thumbsup:
BLUE SPARK do a PRO version for £199 which produces 214BHP and 484nm for £199.....
Just to quantify those remarks - the figures quoted will be at the flywheel for power, not at the wheels (which is typically 15% less). Either way, people looking for more power should have a 'before & after' fitting rolling road dyno printout done. That's the only way you can be sure that the box is doing what it claims. Especially when done at an independent garage, not the supplying dealer !
