Mr2 Turbo Engine Help! Stops Revving At 3000Rpm
Hello,
I'm new to the forum as I have just purchased an mr2 turbo. See picture :)
It starts and drives but there is a problem.
The car seems to lack power and will go up to max 3,000rpm before hitting a kind of limiter under throttle.
It doesn't idle well, it will still if the throttle isn't tapped a little.
Engine management light is on.
I have tried to do the old paper trick clip on the diagnostics to see if I can run up a code on the dash, but failed to do this.
It doesn't seem smokey at all - seems quite normal in that department.
The car won't start on ignition unless I have my foot on the throttle slightly.
The turbo gauge (between the rev counter & speedo) is on max. This could be related or a seperate problem all together.
3,000rpm is it's complete limit, it won't go higher!
Has anyone had problems like this? Does anyone know what the problem could be?
Here she is
post-135966-0-88928800-1384792402_thumb.
