Help
acemiko
:D after deciding to diy my brows have run into a problem have primed and painted but the toyota words say to put the laquer on after 30mins is this right as i brought a Halfords laquer not knowing the paint from the dealer would come with it and on the Halfords one it says to leave top coat 24hr sand to a matt finish the put the lacuer onneed help fast times tickin :thumbsup:
the way i would do it is.
apply 4-5 full cover light coats at about 5 min intervals
then apply light coats of laquer at 5 mins intervals with at least 3 coats, do as many as you want to help make them gleam and protect the paint.
then put them somewhere dry, dustfree and warm to help the paint set and leave for at least 24 hours, maybe 48 to be totally sure if you cant find a warm enough place.
then wetflat with a bit of 1200 paper and then t-cut and polish to perfection!
